SpotlightCreating a lectern
Command
Path
Create Lectern
Event Design
After the stage and stairs have been added, a lectern can be quickly configured and placed. When placed on the stage, the lectern elevation is automatically adjusted to the top of the stage.
To add a lectern:
Select the command.
The Create Lectern dialog box opens.
Parameter
Description
Choose Lectern
Select one of the lecterns from the list; these are configured with default attributes and can be inserted as is. Alternatively, select a lectern shape to use as the basis for a new lectern symbol with customized attributes.
Custom Attributes
Customizes the selected lectern’s default attributes, creating a new hybrid lectern symbol
New Symbol Name
Provide a name for the new lectern symbol; the new symbol is added to the file’s resources
Class
To control appearance, select a class from the list of classes present in the drawing, or create a new class. Leave the lectern in the None class to set the remaining attributes from the dialog box.
Fill Color
Set the fill color for the lectern
Pen Color
Set the pen color for the lectern
Texture
Opens the Resource Selector; double-click a resource to select it
Click once in the drawing to set the lectern position. Click again to set the lectern rotation.
Creating the room for a basic event
Creating a basic stage
Creating basic stage stairs
Creating a basic video screen
Creating seating sections
Creating basic event views
